Enclosure design help for noob. Extra request as well... I know! Geez
Hey guys, I posted over in the "subwoofer" section last night bcuz I was/am going to sell my P3 15's and wasn't sure what to replace them with. I thought I was going to get more out of them, but it's not what I expected and they are just frickin' big. They do get down, but I wanted more out of them. I'm sure most sane people would be extremely happy with them. My friends get in to listen and all I have to do is look at their face/smile. Tells me everything. I drive a 2013 Toyota Camry, read my signature for all my interior equipment, which I will be adding another 4 channel to add a few more mids/highs, but the point of this post is enclosure help. You guys asked me to post over here in the enclosure section, as I have only built a sealed enclosure for my 15's. I'm wondering if I can get the output I want from a single P3 15? Does the P3 handle enough power to give me the DB's I even want (Mid 140's)? If so, here is what I am requesting graciously.
Will someone provide me a box design for a single Fosgate P3 15" that will give me the most bang for my buck, so to speak? I want to hear what this thing can really do. I will attempt to build the box this coming weekend and I will post the results.
Also, the extra request. I know, I'm a pain in the ass. If I don't like the 15, then I plan on buying an AQ3500.1 and (2) HDC3 10's. Can someone provide a box design and try to keep it under 4.5/5 cu/ft with aero ports? Or, if a simple L port will work, then lets rock that... Yes, I already have the electrical waiting for this setup; it just needs to be built. I have a feeling this is the way i'm going to be headed, but you never know if the proper box design for the P3 15 might do the job.
I appreciate any and all the help I can get. This is still a learning process for me as well. I have a great carpenter in the family, so building the box shouldn't be too much of a problem. I just need a couple designs. I will be on the road today for about 8-10hrs, but I will check back in tonight when I get to the hotel. Appreciate it and I hope everyone has a good day!
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
Thanks everyone....
CT Sounds 4000.1D
(4) 8" PRV 8MB450's
Pioneer AVH-X4600BT
Personally I think you wouldnt get as much output out of one p3 as you would 2 HDC's. (could be wrong.... someone else may chime in)
Another thing is what battery set up do you have...? Will you have enough electrical to run 3500 wrms?
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
