Desousa93 Posted April 1, 2014 Report Posted April 1, 2014 SSA XCON 10? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
jarrius Posted April 1, 2014 Report Posted April 1, 2014 How do you know they won't last long? As long as you are sending them a clean un-distorted signal they should last. Also I dought your getting 1800wrms due to voltage drop 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
greezychef Posted April 3, 2014 Author Report Posted April 3, 2014 How do you know they won't last long? As long as you are sending them a clean un-distorted signal they should last. Also I dought your getting 1800wrms due to voltage drop true enough but i will say this. my volt meter stays at 14.4 unless i turn it up past 42. i never do that cause i dont need to. it sounds beautiful and you re right they may last but just looking into my next move if they dont. nothing wrong with that, im still learning all this stuff.
greezychef Posted April 3, 2014 Author Report Posted April 3, 2014 my choice is down between the dc audio level 3's and the Fi ssd's. im may be wrong but for the box i have, i think the level 3's may be better. i really need to learn more about my box. uncertain of the volume and tuning. think i need to start there first then it will all come together.
greezychef Posted April 3, 2014 Author Report Posted April 3, 2014 install was done at Big Daddy's Audio in Longview, Tx. port is on the right side at the back of the box. sorry for the huge pics, not sure how to scale em down.
greezychef Posted April 5, 2014 Author Report Posted April 5, 2014 the rattling sound is because the screw in the upper right side corner of the amp. it had backed out and the sheet metal the amp is mounted to was slapping the amp.
