sicklife17 Posted April 1, 2014 Report Posted April 1, 2014 alright I am rebuilding my box for a sundown sa12 dual 4ohm. I was going to slot port it until I came across these areo ports.Now I have no idea which to use as I am trying to get the box to fit in a certain spot in my trailblazer. If I go with aero ports what size and length should I use to tune to about 33hz? The box dimensions are 29.75w 14h and 12d
Joe X Posted April 1, 2014 Report Posted April 1, 2014 2 4" round ports, would need to be firing sideways due to the length, length is calculated with the PSP inc calculator.
sicklife17 Posted April 1, 2014 Author Report Posted April 1, 2014 Ok I did the Torres calc and got a single 3" about 10 in inches long. Why would I need 3?
Joe X Posted April 1, 2014 Report Posted April 1, 2014 Due to port area, with a single 3" you will get really loud port noise, if you are going by Torres look the manual, it says 9-12 square inches of port area per cubic feet of net vol, while this is a cheap rule of thumb it still gives you an idea where it need to be.
sicklife17 Posted April 1, 2014 Author Report Posted April 1, 2014 So I should just stick with a 1.5inch slotted port
Joe X Posted April 1, 2014 Report Posted April 1, 2014 If you can pull something like this you may save some space, those are 4" ports:
sicklife17 Posted April 1, 2014 Author Report Posted April 1, 2014 and how long do those have to be?in this case what would be better aero or ported? and how much air space will i end up with?
Joe X Posted April 1, 2014 Report Posted April 1, 2014 Both round and slot can work, round just save space, just enter your dims in Torres and adjust ports length to get your tuning, if it all fits like in the pic you are good to go.
sicklife17 Posted April 1, 2014 Author Report Posted April 1, 2014 So i would need 2 30in long tubs. Wouldent that take up bassicly the hole inside of the box?
Joe X Posted April 1, 2014 Report Posted April 1, 2014 This is why few people are willing to work with round ports, anyways three 3" ports 24 3/4" long ( 5 1/2" external and turning like in the pic) and using 5/8" wood except for the baffle would put you around 1.83 cubic feet @34Hz, don't know if it's feasible since I would need to draw it. This is the most space you can get on those dimensions.
