First,
A welcome to the best audio forum on the planet.
Second, there are certain sections for questions. Like..Electrical/batt/alt area where this would go.
It will help you get an answer better, if you land them in the "proper" spot.
Third, what platform/vehicle is this in?
If you have a true DC alt in it, and it is running as it should, IMHO youd have NO problem running said 2k. I may add a rear bat, depending on how low you wire down, but,...... If that is a true DC alt, IMHO youd be just fine.
Again, welcome to the forum. :drink40:
Wouldn't hurt to have an extra battery hooked up.
If you had 14.0 volts at the power terminal on the amp then 185 amps would allow for up to 2590 watts. ( 14*185 )
If your amp is putting out 2000 watts rms and is 80% efficient then it will draw about 2500 watts. ( 2000/.8 )
However your vehicle will also have other electrical draws on it. And you only get the rated output of the alternator at higher rpms, so a demo at idle might give you a bit of voltage drop.
Chevrolet Tahoe
Crescendo PWX6 (2) and FT1 (2)
Fi Audio SP4 15" (1), AQ3500D.1 (1)
Enclosure: 4th Order (Ported) 4.5cu ft @26Hz
Mechman Elite 370A & Kinetik HC2000
Sky High 2/0 Wire
Future Plans: (2) 18" @25Hz
  • Who's Online   0 Members, 0 Anonymous, 2516 Guests (See full list)
