speaker wire.
jmfrb1
What bolts/lugs do you guys use to connect the speaker wire from your subs to your amps? Never gone this route and planning to soon so I'm curious.
Most of the amps I have owned I just run the wire right into the mechanical lug on the amp. Now I have seen some cheaper amps with like a screw terminal where you can crimp a fork. You can solder the end of the wire or I like these also
This is a 1/0 lug but you can get all different sizes, we sell Burndy at my work
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
I meant more for like a jumper cable system to change impedance without taking the subs out. I think I'm making it too complicated to explain. I'll get a picture after work
I just use some copper washers and steel bolts and put a wing nut on with
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
You can get aluminum bolts & nuts from this place: http://www.mcmaster.com/#standard-cap-screws/=rh5s7i
Just select aluminum from the list of materials on the left hand side of the page. I use 1/4-20 size. Much better than steel from an electrical perspective.
Builds:
Ah ok I understand now sorry.
PIONEER DEH-P8400BH
2 CROSSFIRE C7 18
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
