FknCrawler Posted May 18, 2014 Author Report Share Posted May 18, 2014 It was hard getting the shape for the pocket because the door panel doesn't lay flat without flexing the door panel. 1992 Honda Civic CX Hatchback K24a2 Swap Link to comment Share on other sites More sharing options...
JNells Posted May 18, 2014 Report Share Posted May 18, 2014 There ya go, looks like you're getting the hang of it. Gonna need 3-4 more layers of Mat and you'll be good to go. In my opinion the base mold is the hardest part of the whole process My only suggestion is to cover up the cloth part of your door panel (with tape, plastic, tinfoil etc) ... It'll be almost impossible to get out if resin gets on it. Malibu Build Log Link to comment Share on other sites More sharing options...
FknCrawler Posted May 18, 2014 Author Report Share Posted May 18, 2014 Thanks! I had to covered as I was laying down the resin but It ended up getting ripped so I took it off after I finished up. This uv resin makes the work much easier. 1992 Honda Civic CX Hatchback K24a2 Swap Link to comment Share on other sites More sharing options...
FknCrawler Posted May 23, 2014 Author Report Share Posted May 23, 2014 Haven't done squat.... My job is killing my motivation. Did get around to making two tweet speaker rings and two 6.5 speaker rings, need two more to be done. Not an easy task with only a drill, jigsaw, and sanding by hand, and 95+ heat. Gonna try to add more layers to the door panel for strength then glue these rings and stretch the fleece. 1992 Honda Civic CX Hatchback K24a2 Swap Link to comment Share on other sites More sharing options...
kjvsop Posted May 24, 2014 Report Share Posted May 24, 2014 Haven't done squat.... My job is killing my motivation. Did get around to making two tweet speaker rings and two 6.5 speaker rings, need two more to be done. Not an easy task with only a drill, jigsaw, and sanding by hand, and 95+ heat. Gonna try to add more layers to the door panel for strength then glue these rings and stretch the fleece. Tuning in, considering trying something similar. Kicker ZXS 1500.1 Solo-Baric S12L72 (2) ZX 650.4 KSC693 6x9 (4) PKD1 1/0 AWG K-Series RCA's 4 AWG Big 3 85 Monte Carlo Link to comment Share on other sites More sharing options...
