Sundown SA12 help needed (box design and power)
got a pair of sundown SA12 subs
im looking for the best advise from you guys in terms of box design and what power should be used to play them
overal objective is to get the most performance out of these sundowns subs
im not a big fan of low lolw bass but would like to be able to get all bass notes from high bass to low bass
example would play all bass notes from songs like late night tip.. heartless.. put on.. ( so getting lows and highs)
amp i currently amp is a orion 1200D rated 1200rms@1ohm @ 12.8V
if i have to upgrade my amplifier. what rms power raing should this amp be doing?
as for box: my max height: 17.5" high, my max width :38.5", width: have up to 22" but would like the box as short as possible with my max hieght and width
so the help i would like to get iis
1) to a box design to achieve the most i can i get out of the SA12 to b e able to play highs and lows and play them well
2)what rms power would u recommend on a pair to play them to get the performance daily without causing damage to them
all help would be very appreciated .
and i hope yall could help alot since yall have would have alot of experience with them
Well not even telling what vehicle is it. Anyways 1K RMS unclipped per sub is safe to give, will never have a problem with that amp.
The nearest to flat performance inside a vehicle is a sealed enclosure which basically no one wants to do.
  • Who's Online   0 Members, 0 Anonymous, 3203 Guests (See full list)
