i got you bruh..... gimmie a bit.
and these are going to be VERY general examples.
6th...
The red section is your "1st Ported" box [or chamber], which would generally be low tuned. The orange section is the "2nd Ported" box [or chamber] which is generally tuned high. The small rear portion (red) with low tuning helps retain cone control and front portion (orange) is more of the output section.
4th...
The red section [ first chamber ] is a sealed section, while the second chamber is a moderately high tuned ported section [ orange ]. Same sort of mechanic going on with the rear and front chamber.
4th...
So these are generally large builds?
Here is a 4th order. See how where the subs are mounted the chambers are sealed, and then there is the middle chamber (front or 2nd chamber) which is ported.
6th order.
see how the rear chamber (which holds the subwoofer) is vented or ported into the front chamber, then the front chamber has another bigger port exiting the 6th order.
4th...
yes, due to the fact you are basically putting the sub in a sealed and ported box... so almost 1.5times the volume of a normal box.
  • Who's Online   0 Members, 0 Anonymous, 489 Guests (See full list)
