Single xfl 15 enclosure help!
Chrisxfl15
Ok guys I have a 2003 dodge stratus r/t coupe, I have a american bass xfl 15 and I need to build a ported enclosure, I would like it to be tuned around 32hz-34hz please help! Thank you
Need max dimensions, amp you're using, etc.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
17 inches wide or deep?
oh lawd.
Audio pipe apsm 1500, max size it can be is 24in long x 17inch wide and 17 high, I have a box in the car right now sounds like dirt atm.
The reason it sounds bad is the box is too small and your max dimensions you state are small as well, guessing why, the trunk of that vehicle is pretty large, if you are unwilling to give up more space I would recommend going for a 12" or 2 10".
  • Who's Online   0 Members, 0 Anonymous, 3493 Guests (See full list)
