Cutting metal out that braces the trunks spring lifting system
how do i cut all this metal out to do all wall off while keeping the trunks lifting system still operational? at the moment im not wanting a wall off yet but would like to cut this metal out to allow better flow from the trunk. any advice would be great thanksa388b0b9-9ac4-47e4-9cc4-4377eb730913_zps
Your car will probably handle like dog shit and have A ton of body roll after you cut that. That metal is there for a reason, I'll wait for someone else to chime in tho
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
What was already said=will lose structural integrity..probably hit a pothole or
something and trunk suddenly doesn't close like it used to..probably have to
build a frame around area to be cut first,then weld,then remove the offending piece.
Removing any major piece like that, especially if you are going to cut it out, is going to need a frame to reinforce it afterwards its definitely a good choice if not a necessity .
  • Who's Online   0 Members, 0 Anonymous, 1216 Guests (See full list)
