2 1500.1bdcp in spare wheel well and heat?
alaskanzx5
Plan is to put 2 t1500.1bdcp in the spare tire well of my 2000 focus hatchback. Measures 25" side to side 25.5 front to back and I'll have a total of 5.5" depth. Now they will fit with roughly 5" of space between the 2 and 2" between them and the walls of the wheel well. They will have just over 3" clearance above them.
thinking it might be a good idea to do some fans but how? I'll have the speaker box right on top of the wheel well so I can't do fans pushing air in and out from the top. If I do fans pushing air in and out through the wheel well walls then in wet/rainy weather I could get excess moister in there which is a no go for the amps.
any other ideas or don't worry about fans?
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No suggestions?
amps will be at 2ohms and I'm thinking maybe a fan blowing across the 2 amps for air movement. Figure that should be fine.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
