cloud77 Posted May 3, 2014 Report Share Posted May 3, 2014 sounds like you have an install problem.. That's all I got. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A Link to comment Share on other sites More sharing options...
ReeseChamp Posted May 3, 2014 Author Report Share Posted May 3, 2014 Then go and get a 1.5v battery and touch the terminals to it (you may need some short wire) to be able to find which way all the coils need to be wired to have it push the cone out. i think i know what you mean with the battery, like test each terminal on the one sub seperate to see if its just one side that could be mixed up, ill try that when i can find a battery Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS Link to comment Share on other sites More sharing options...
Guest Posted May 3, 2014 Report Share Posted May 3, 2014 maybe the factory swapped the + and - by accident post a diagram how you wired it Link to comment Share on other sites More sharing options...
ReeseChamp Posted May 3, 2014 Author Report Share Posted May 3, 2014 Then go and get a 1.5v battery and touch the terminals to it (you may need some short wire) to be able to find which way all the coils need to be wired to have it push the cone out. http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/1-DVC-2-ohm-mono-low-imp.jpg this is how the subs are wired now,each sub has this same wiring going to my amp Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS Link to comment Share on other sites More sharing options...
ReeseChamp Posted May 3, 2014 Author Report Share Posted May 3, 2014 i suck at using forums btw as you can tell with my hack job replys Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS Link to comment Share on other sites More sharing options...
PolishThunder Posted May 3, 2014 Report Share Posted May 3, 2014 You said you have two subs but the diagram you posted is for one sub. If that is what you used to wire it I'm really confused or maybe it was just an error. Link to comment Share on other sites More sharing options...
ReeseChamp Posted May 3, 2014 Author Report Share Posted May 3, 2014 You said you have two subs but the diagram you posted is for one sub. If that is what you used to wire it I'm really confused or maybe it was just an error. both of my subs have the same wiring as the one sub in that picture, its the first one i found Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS Link to comment Share on other sites More sharing options...
tacomaguy1 Posted May 3, 2014 Report Share Posted May 3, 2014 Out of phase Wired wrong at sub Switch positive and negative on one...problem solved Team Flex Issues Link to comment Share on other sites More sharing options...
ReeseChamp Posted May 3, 2014 Author Report Share Posted May 3, 2014 Out of phase Wired wrong at sub Switch positive and negative on one...problem solved i checked both subs they are both wired correct, the only way theyd be wrong is if the manufactuer mixed the + and - Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm Door Speakers - RE REX 5x7/6x9 Battery - Kinetik HC 2000 Sub Amp - Crescendo BC2000 Door Amp - Alpine MRP-F300Head Unit - Pioneer DEH-X8600BS Link to comment Share on other sites More sharing options...
tacomaguy1 Posted May 3, 2014 Report Share Posted May 3, 2014 Which can happen Team Flex Issues Link to comment Share on other sites More sharing options...
