Have 2 subs but they move opposite of eachother
that ground is not good at all.. fix it
its not the reason why your subs are out of phase but looks like you have more issues than one
should i unscrew it and steel wool it more?
Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm
Door Speakers - RE REX 5x7/6x9
Battery - Kinetik HC 2000
Sub Amp - Crescendo BC2000
Door Amp - Alpine MRP-F300
Head Unit - Pioneer DEH-X8600BS
Yes, bare metal in contact with the ENTIRE lug.
I am 60 miles north of this guy. have a dd-1, and a MM and you guys have seen my build so you know i am not stupid.
If he wants to meet half way I can try to help him out no prob. Just give me heads up here tomorrow and let me know what you want to do. I can't guarantee i can be somewhere at the drop of a hat. But my schedule is pretty clear tomorrow.
you need to bolt it down not screw it on.. try and find a more solid spot and bolt it.. try and wiggle it and you will see it will move around. could be the reason your amp was hot to the touch
im clear tomorrow too if you wanna pick a time i can go by your time
you said you have a multimeter now, so before you make a trip up here, check each coil using them "ohm" setting. see if they are all they same.
With them unhooked of course.
edit:
it may look like a horseshoe on your meter.
edit:
alright ill go and check now hopefully it gives somewhat of a accurate reading
they are both around 4 ohms on both sides
Good, then you just have a wiring issue.
Just positive to positive, negative to negative. It's as simple as that.
  • Who's Online   0 Members, 0 Anonymous, 611 Guests (See full list)
