Ahmed Johnson Posted May 6, 2014 Report Share Posted May 6, 2014 From my experiences stinger sucks but that isn't the issue. How is your ground to the amp? Do you have pics? Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 I turned the gain down about a quarter turn and the amp stayed on... Sub played through the low notes but it sounded terrible Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2014 Report Share Posted May 6, 2014 What about the other issue that is cause the sub to go crazy at times... I've checked the coils on the sub they are good... I don't trust that light for 1 second... I've had that light come on when at a low volume with the knob all the way down... Also, Audioque knobs go bad... A lot... I've replaced mine 3 times and 2 times on the 2200 I had yes i'm aware. i've replaced mine already. my clip light wasn't very accurate. oscope showed clean while red light was solid on. Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2014 Report Share Posted May 6, 2014 I turned the gain down about a quarter turn and the amp stayed on... Sub played through the low notes but it sounded terrible maybe your box isn't good. Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 From my experiences stinger sucks but that isn't the issue. How is your ground to the amp? Do you have pics? Unfortunately I don't...I had it all hooked up at a local place that is very good... The box design I had, has the amp "inside" the front of the box with the wires running through the box in the concealed amp area, under my third row seating area Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted May 6, 2014 Report Share Posted May 6, 2014 Do you know where the ground is going? Link to comment Share on other sites More sharing options...
Marquisboys Posted May 6, 2014 Report Share Posted May 6, 2014 Yeah i think your volts are going lower than u think. The Stinger volt meter is digital and cannot read your volts as fast as the analog one steve meade has. 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 Yeah i think your volts are going lower than u think. The Stinger volt meter is digital and cannot read your volts as fast as the digital one steve meade has. I'm checking at the amp as well while it's playing and the Stinger voltmeter is spot on my fluke meter reading Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 Do you know where the ground is going? Grounds from front battery, 4 channel, and sub amp are all on the rear battery (XS Power D3100) and from there, have a metal bar running to the frame of the 3rd row seats mounting bracket it appears... Solid connection it seems... Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Marquisboys Posted May 6, 2014 Report Share Posted May 6, 2014 well at least you found out why the amp was going into protect mode. Now for the tuning side of it go around 5hz lower than your box tuning for the subsonic and have your low pass at around 80hz if you want.. some ppl do more and some dont. You might need to build a new box also. Did you build this one to the subs specs or is it prefab? 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune Link to comment Share on other sites More sharing options...
