RF 3Sixty.3 Question
I know you can stream to it via Bluetooth, but can Bluetooth be the "primary" connection, so when it turns on, its already on Bluetooth? I have a 3Sixty.1 right now, and if you are using the AUX input, you have to manually switch to AUX every time you want to use it.
Also, do you have full EQ control when in Bluetooth mode, or is that only when using RCA inputs?
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
  • 3 weeks later...
I haven't used my bluetooth but I imagine it stays where you left off as you switch sources when you push in on the "bass knob" when setting up you asign preset. EQ control is more set and forget regardless of source. if you want to tinker with the EQ bands you have to log into it with a laptop.
  • Who's Online   1 Member, 0 Anonymous, 1455 Guests (See full list)
