94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
What do you mean? I RTV'd all around the timing cover, backing plate, water pump, the two outlet spouts coming from the timing cover and then water pump, and even did the thermostat housing and thermostat neck. Intake is done too.
The part that's leaking is the hose itself where it goes on one of those spouts. It's the one, OF COURSE, that's going into the thermostat housing, which doesn't come off without taking the timing cover, and water pump off.
However, I believe the problem is, I used the cheapo hose clamps that are like bands, and I need the spring clamps like what was on them when I took it all apart. I thought I saved those in the box of screws etc, but I'm not seeing them anywhere. These hose clamps I bought, are not strong enough to hold them. This is literally the only leak and only issue I'm having so far.
I'll be stopping off on the way home from work to see if I can get a spring clamp instead, and actually I'll get one for both heater hoses too. No reason to use one on one of them and not both.
Unfortunately, I broke my internet at home somehow. After uploading all of those pictures this morning, I load them onto Facebook and the drag and drop them here, my internet went down and I can't get a tech out there until Thursday sometime. So, I don't know when I'll get the pics over here.
If you want to check them out now, you can see them at: Ford Beast 350 Engine Makeover
I know some of you hate to go over and look at facebook, and that's not what I'm going to leave it as. I'll get them over here, I just have to wait until I'm on a computer I can do that on. I don't have time to do it at work, and I'm training tomorrow, so I won't be here anyway. But if you want to see them, they're on my Facebook page that I just linked, under Engine Makeover.
Thanks for checking this out.
Your attention to detail is amazing man. I wish I had that
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Thanks.
Little update, still no internet service. They're supposed to be there tomorrow around noon to fix it. So as soon as I get service again, I'll start posting pics and videos.
I'm so excited, I've driven it a couple of times around the block and she drives fantastic. Haven't really wanted to push it much, just doing normal driving. At least that's what I read on what you should do after a rebuild. But I'm guessing that's with pistons etc replaced too. Remember I just did the top end, so maybe that doesn't apply. Just a little gun shy, since I'm not experienced here.
Tomorrow I'll be going to the dump in the morning to empty her out. She became a kind of catchall while she was on the side of the house. LOL. Then I'll see what happens after that when she's empty again.
Time to start getting into the F250 now. I'm planning and have ordered some stuff for a special project so we'll have to wait and see what that holds. That will be in the other thread though.
Thanks everyone, hopefully tomorrow I'll have pics up.
The lower intake on front and back has water jacket ports to transfer fluid from head to head across the intake. Aka intake gaskets. The water ports on the intake gaskets is what I was getting at.
I wouldn't figure a hose clamp is gonna cause a leaking issue ive seen the neck themselves pit away and leak. From corrosion. Not hose clamps. Could try the hairspray method before taking it all apart again lol
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
I drove it around all day yesterday and no leaks. So I got it stopped. It's got so much more power than before I started this thing. Even before the gasket blew, I just did not have this kind of power in it. It flat out goes now! So happy!
Internet is back up, so I'll try and get pics up tonight and finish this thing off.
I picked up a bunch of plasti-dip yesterday too. Gonna make her look nice and get her ready to sell.
Ok here goes. PICTARS!!!!
So for the last two years, up until about 6 months ago, I've been dealing with real bad pantar fasciitis. When I'm on a ladder it's really really bad. So I had been on a ladder for the previous 2 weeks helping a friend with his house, and had been working off of a 4ft ladder to do this truck. It started coming back, so I picked this up from Home Depot. Man what a lifesaver for $50. It's a platform, workbench, can use it as a furniture dolly, or a creeper. The top, orange, flipps over and it's got an mdf smooth side with some numbers and angles etc for a workbench. This thing may be the best thing I've bought in a very long time.
11850665_773309802778152_532521541662586
It also has a spot on the end there that you can connect electrical if you need it. But this is where it resided most of the time. I used it as a creeper too. That was pretty damn handy.
11879077_773309816111484_732637337707168
Also picked up some new air hose. Put on a 3/8" end and made a 3/8 to 1/4" whip for other tools. The 3/8's is being used for my air impact gun. Big difference.
11875074_773309819444817_705344096367741
11816317_773309872778145_818775405428933
Ok let's get to work. Time for the headers. Using this copper spray a gasket sealant to help the gasket stick and seal.
11802598_773309919444807_779490908029063
Sprayed both sides of the gasket
11794601_773309946111471_660387972490667
as well as the block
11229846_773309972778135_354266394043343
Then bolted the header on. That was a tough job. I forgot I pulled the header after the heads and covers were off. This was a bear to get in this way. But I managed.
11816157_773310016111464_850487792829946
Part of the Emissions system, getting some copper spray on it too.
11850635_773310136111452_557350413776795
More emissions.
11728928_773310156111450_207024207191192
This was a pain, because it had to go in behind the motor and down to the other set of headers.
11807283_773310159444783_566159620165437
Got the brackets on, and the Stage 8 tabs and clips (on the spring) are about to go on.
11878904_773310192778113_685680497292022
Driver side, basically the same process.
11878974_773310272778105_705673497653057
11875045_773310319444767_625856009747402
11838963_773310359444763_324505545104741
11845108_773310409444758_390191427824675
11794454_773310462778086_670462051187236
I did have to trim this up a little bit. The previous bolts, were a bolt with a nut on it, and then another bolt on top that this bracket was held down to with a bolt. So it probably sat about 1/4" to 3/8" higher previously. With the new bolts, it's just a bolt. So the edge, on the left side of the bracket, hit the head cover.
11823091_773310486111417_769652864977408
EGR valve spot.
11838688_773310516111414_377230555847975
EGR Valve ready to go home.
11823126_773310589444740_738292520182317
Got that on, and the tube that goes down to the headers tightened up.
11875059_773310619444737_748700848124610
Coil, Emissions stuff, and whatever else that went on this bracket. If you look close, you can see where I took the edge off of the bracket below the coil there. There's about 1/4" of clearance there now.
10960207_773310662778066_559639200425946
11807395_773310706111395_875187642927300
Power steering bracket, tensioner, and power steering pump ready to go on.
11794466_773310742778058_557266969851994
It goes on the right side head, where the 4 holes are drilled into the front of the head.
11791933_773310766111389_839250230051911
Just like this.
11845023_773310819444717_587318269090448
Upper view
11807129_773310842778048_178335069246694
I was putting the A/C pump on and I decided it needed a little touch of love. It just didn't look right next to everything else that's been painted and cleaned up.
11807283_773310969444702_670804842873872
Got the o-rings out and put them in a bag.
11222218_773311032778029_693504688122118
11807182_773311069444692_457463290988371
11834758_773311186111347_257881830869903
then got to cleaning it up.
11112320_773311209444678_300197411777648
Forgot pics of the clean up process. But she got painted as you can see here. Looks much better.
11879173_773311219444677_739417638702130
11823158_773311249444674_326555629128416
11816095_773311322778000_245936017348683
Power steering pump line.
11794552_773311342777998_790445041455367
Getting the power steering pump lines all attached.
11224186_773311372777995_583333240027261
11834800_773311426111323_194598050386087
11807227_773311439444655_630481106962905
The long line mounted.
11864994_773311449444654_420655715292966
Then got the A/C pump in place. That looks 100 times better than it did previously.
11222218_773311496111316_786182183002612
Just gotta put the A/C lines back on and that part will be done.
11822964_773311512777981_735625644745461
11878894_773311542777978_749452726950538
That side is pretty much done.
11875135_773311569444642_818685045649576
Alternator bracket, Smog pump (gutted), and Alternator are next.
11055398_773311642777968_556863175436746
It goes on the left side head.
11807328_773311699444629_714769232840375
again, I put the alternator on the bracket, and it was in bad need of some help. So, let's help it out.
11802526_773311702777962_460246510112009
11850694_773311732777959_913520571176145
Took the pulley off.
11879257_773311802777952_685634648806674
11875138_773311806111285_489836476543199
Took the regulator off.
11246970_773311846111281_754440227129454
11879165_773311942777938_503230600319852
11865109_773311966111269_833459000301600
Took the case bolts out.
11816332_773311969444602_420281395191176
And let the fun begin!!
11145076_773312056111260_870296472677845
So this is the end result. It took some serious work to get these all apart. But I managed to do it. Basically what I had to do was use a sand filled mallet, and hit the case where they meet in the center and hit all around each ear (where the bolts go through) until it came apart. Once that was done, getting the center pieces out was pretty easy. You can find all kinds of videos on youtube for this.
11878946_773312109444588_729163608570586
