Looooooooove what I'm seeing. Prolly gonna pretty much copy exactly what you have done there. I put two 6.5" in each of my door panels in the same spot as you and with 3/4" MDF rings BUT did not glass them all nice, got them in for some tunes for the time being but it needs some TLC for sure.
Your work looks great man. tuned in for end result!
Thanks! The passenger side looks way better than the drivers because I used a thinner fabric instead of fleece. I'll be uploading more pictures today.
Awesome work
Thanks man.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Looking good man. Too bad that white box won't match.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
So I cracked some of the plastic with my air stapler so I decided to cut back and re build it.
10383773_10154182108940408_7067319408004
10012519_10154182108765408_7943748113257
10390557_10154182109455408_2813787038003
10346471_10154182110230408_3540225655911
Add some kitty hair
10351818_10154182110975408_5308527316178
10479101_10154182110080408_6934716391349
And here's the passenger side. Looks much better.
10450306_10154182108550408_8720842374409
1498989_10154182111590408_56382007170315
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Still have to do some more glassing but hopefully this week ill start up some body filler.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
No major updates other than sanding door panels. Oh shit I lied. Didn't like the size of the enclosure so I hacked it up and took some volume out of it. I don't know if my software did something wrong or whatever but the it did seem a bit too big, but I figured I'd try it out. I've built large enclosures before and had some good results but I guess 15 cuft is too big. Anyways, I wasn't to thrilled with the performance, so i cut it down to 10.5 cuft. I know...fuckin' goon at work here.
10474765_10154209241095408_6920470300994
10428346_10154209241150408_2910128399677
10460835_10154209240985408_9041121747139
10447094_10154209241665408_8540528654202
10348774_10154209241825408_4096209776430
Blurry as shit because I wasn't wearing my glasses.
Long story short, I cut it, I glued it, and put screws in it. At this point I dgaf because I might just rebuild the enclosure.
10495096_10154209241810408_4150993239802
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
And door panel progress:
10443603_10154209290500408_4692294093527
10446142_10154209290670408_3021628606291
Pink.
10422964_10154209290595408_7976947296259
10464227_10154209291375408_4293554883075
Sanded. Fuck I can't take pictures without my glasses.
10457686_10154209291465408_5196328050140
10497415_10154209291880408_1157479002740
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Anyways, I was going to bed liner the doors but I found some vinyl that almost perfectly matched the stock texture of the doors so I'm going to try it out.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Doors came out really clean. Looks pretty seamless with the contours of the door.
Were you just using staples to hold the fabric to the door?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Thanks. I used contact cement with staples, though the cement was a cheap brand and didn't work too well.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Okay, so I royally fucked up on my enclosure. Worry not, I have a proper design now that I worked on for a few hours last night with some help from the forum.
Here's what I got: 10 cubic ft, with 165 square in of port, tuned to 28 hz.
I'm only going to double up the baffle this time round and brace to save some weight instead of double thick all around...the current enclosure is a pig to move around.
10482102_10154222154705408_1150211211802
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
