jessdabest77 Posted May 17, 2014 Report Posted May 17, 2014 I have an 02 Nissan Frontier ext cab that I'd look to put either a set of comp set 6 1/2's or coaxial 6 1/2's.I already have a set of comp's in the door's,but I'd like to put another set as well,without fiberglassing the door's or kick panel's.The back has a big box with the sub's,so it'd have to be up front.Any thought's?
pickup1 Posted May 18, 2014 Report Posted May 18, 2014 Subs go from floor to ceiling? No room to put anything back there? Are you looking for more sound up front? With no other factory locations available, you'll either have to cut something or have something made.
jessdabest77 Posted May 18, 2014 Author Report Posted May 18, 2014 ok,i cant do anything behind seat's.
trumpet1 Posted May 19, 2014 Report Posted May 19, 2014 You want more speakers without fabricating anything? For 6.5s that's not gonna happen. You could try this: AF-256/020 Accent Fill System Use Scotch #4011 Permanent Outdoor Mounting tape and the pods will stick to your panels until you're ready to remove them, then you slide a thin wire along the surface to break the bond. I have an 02 Nissan Frontier ext cab that I'd look to put either a set of comp set 6 1/2's or coaxial 6 1/2's.I already have a set of comp's in the door's,but I'd like to put another set as well,without fiberglassing the door's or kick panel's.The back has a big box with the sub's,so it'd have to be up front.Any thought's?
