Ground wires
Ok so i have a question about grounds my current setup is 1/0 gauge wire from positive terminal on battery under the hood to positive terminal on a xs3400 in the trunk then another 1/0 gauge wire from negative terminal on battery under the hood to negative terminal on the batt in the trunk on the batt in the trunk i have duel ring terminals my amp is hooked directly to the 3400 ground and power. Now im wondering if my setup is ideal or should i put in a second ground to the battery in the trunk? i have a uni-body car but there is some thick metal in the bottom of the trunk that i could use for a ground if i wanted. The current setup works good but im wondering if there is room for improvement, here is a pic of what ive got. IMG_20140519_2003001_zps19cd1042.jpgIMG_20140519_2003051_zps8fbf481b.jpgIMG_20140519_2003181_zps0a118285.jpg and yes the black wire is my power wire i will explain why if anybody wants to know. :D
Yea i've seen guys at shows with 20 (-) grounds off their rear batts
There should be a "Body" ground within 18 inches from EACH battery.
When I say 18 inches ... Meaning the length of those cables should be no longer than the maximum length of a battery.
noted and on to-do list for this weekend
Oh, and if you are (or plan to) run HID headlights, make sure to ground each ballast withing 18 inches of each ballast too.
Helps prevent motor noise (engine whine)
dont plan to just because i dont want the expense of the entire headlight assebly cuz my stock ones aint made for hid
im just gonna install bad-ass foglights someday :D
I use a die grinder to clean the body's metal before installing my grounds to the body.
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
