MTX 92001 in need of help
412"ranger
hello every one i have a mtx 92001 amp that was working great until just a couple of the days ago it stop playing but then after 2-3 secs it plays again the amp is on all the time when it does this. It will work only at very low volume without stopping sound (music) I have open the amp up and look for burns nope burn smells nope but it does make a noise when its on i will link a video of the sound
thanks guys let me know what you guys think it could be thanks again
video
http://s1359.photobucket.com/user/FI...785cb.mp4.html
Does the amp go into protect then back on? I just had an issue yesterday with my amp and when at low volume it was fine. Once I went past a certain volume it would go into protect. Wasn't an issue with the amp though. Sub is bad although it reads the correct ohm load. Put the sub on another amp and see if it does the same thing to the second amp. If it does you may have and issue with one of your subs.
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
mmets thanks for the replay i just tried a different sub but it sitll it does it. the protect light does not turn on the amp when the music cuts off. i have the subs at 1ohm checked with a ddm.
Check power wire, all fuses going to amp, check ground wire, make sure connections are secure. after that is all said and done and it still does it may have an issue with the amp.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
i found a loose cap put it off
can i just a get a cap 35v 1000uf i was looking and there is alot of different one which one do i need any help will be good thanks
Well with that one you went past my level. I did repair an old pioneer deq9200 before. I would contact mtx or maybe a amp repair shop, you may be able to order through them the part you need or they can tell you where to get one. Just my thought though. Good luck with it.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
thanks for your input i will email mtx
  • Who's Online   0 Members, 0 Anonymous, 685 Guests (See full list)
