please help me out(sub box)
tmac93
im trying to build a ported box for my orion hcca 10.2 , I don't really know where to start and I need a little help to get going, ive only built sealed enclosures in the past, and im having a hard time understanding how to build the box, as in porting it and such. im wanting to do a slot port, maybe tuned to 30-34hz. I listen to mostly slowed rap music and Decaf. so daily use.
orions specs say box size should be .75cuft ported with a 2.5''x2.5'' square port. that just doesn't seem right to me, that small of port would cause port noise correct? and only .75 for this big ass 10''?
if anyone can help me out, my max dimensions I can go with in my trunk is (32" wide, 24'' depth, and height of 15'')
this may also help.
Fs - 42.51
Vas - 0.31029
Qms - 7.16
Qes - 0.48
Qts - 0.45
Bl - 23.3
Sd - 51.66
xmax - 25.89mm
Le - 1.93
Re - 3.9
displacement - 0.1268
((I calculated my minimum port area to 33.28in on a site)) <--- not sure how to use this number
maybe throw me some box plans or a design maybe? I want it to really slam and give me the most while sounding good.
.75 cuft sounds like that would be the specs for a sealed box. I would say about 1.5 cuft for a ported encloser.
truthsayer
the spec sheet for this is weird, its .75 for ported and .9 for sealed, never in my life have I seen something like that, its usually the other way around.
and its powerd by an hifonics brz2100.1 not the best and efficient amp, but its what I will be using
so if I go with 1.5'' cuft and I need 33.28in of port area, I can go with say 11x3, at 32hz it gives me 53 inches of port length???
guess i'll prolly have to go sealed, its to hard for me to understand all this. I flunked math multiple times in school, and ive been reading on stuff for months and months trying to figure this out, but after multiple posts I still cant get the help I need on here
Download Torres box builder, it'll help out big time on figuring out measurements for ports and such.
now where it says port length 45'', how do I measure out 45'' of port? this is the part im so confused with.
  • Who's Online   0 Members, 0 Anonymous, 2843 Guests (See full list)
