4th order walled Civic (DC/PSI 18's/CF 8K/ RF 360.3 UPDATES APRIL 24-2015
  • 1 month later...
Got a few updates on the build, bought my bass amp for teh subs will be driving the Toronto in the next week or so to pick it up.
11062375_435285653297170_819164229594499
Started the work on the new wall going in, going from a flat wall to a 4th order wall and going to try and re-use my shell from the flat wall.
10428611_426342444191491_782519351575789
11042653_426342460858156_795816742357150
10981834_426342477524821_515882302073819
10502132_426342450858157_594623877564328
Went out and got two sheets of 3/4" MDF to build the new wall 2:1 4th order wall.
11083647_435915319900870_784293977601695
Now just have to decide on how to build it, do I do seal portion on the back wall and have the ported side in the front OR do I build it with the seal portion on the bottom with the ported side on the top. Can't make up my mind, any pro or cons between the two build?
So I started on the front end conversion on the Civic, going from a 97 Civic front end to a 97 Acura EL front end.
Before and after, the EL front end is just sitting there and not bolted down going to paint the red in the front flat black.
11081439_436381986520870_410785965554351
11102793_436381999854202_550700979975534
11081316_436382023187533_682180754895226
Once I can make up my mind on the 4th order, I will start building.
The reason that I'm not sure on how to build it is,
if I do the subs facing foward and invert them the motors will be 4" away from the loading wall.
if I do the subs facing the roof, invert them ,the motor will be away from the roof 4" tarward the back and 7" toward the front.
Is there a limit to how close the motors can be from the box?
Why not just flatwall it with a driver side port? The extra space will help with efficiency and it doesnt seem worth the trouble if the bandpass doesn't come out how you want it.
Your really just restricting yourself if you think about it.
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
I didn't think DC's liked fourth orders.. I could be wrong?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
