4th order walled Civic (DC/PSI 18's/CF 8K/ RF 360.3 UPDATES APRIL 24-2015
Thought I would shared my wall build, The Civic was bought to wall it off but wasn't planing on doing so till next summer so I started off with a no wall trunk build that lasted a few weeks after I was done. It had to go and started the wall, I on't have the weekends to work on it unless I get off work early.
Started off with 2 HDC3 12" on a pair of AQ 2200. Wasn't sealed off as the box was a temp box as I started to design a box.
Then got a good deal on a SSA Zcon 15" on a single AQ 2200 did a 143.9 @ 30Hz
Wasn't enough so it had to go
Let the fun begins
Don't mind the small 2 X 4's they were just to see how far I had to go with the floor till I reached the rear deck.
Filling in all the holes with wood filler.
First of 4 layers of mat.
All the seams got 2 layers of mat.
While the mat dryed I cut out two of the baffles.
Baffle one.
Then the fun began with sanding, sorry for the bad picture. First time I ever worked it the stuff and let me tell you I wanted to give up after a few hours. lol
Messenger_5874313935337132081_1400545581
Took a break from sanding and went out and got 2 more sheet of 3/4" mdf.
1964780_300725026753234_4442241640464067
Then it was time for filler.
10361338_301959113296492_150843409405529
And some more sanding.
10306743_303833969775673_485022474885490
After the sanding was done it was time for resin, 1 coat of 3.
10296767_303932483099155_464935043667274
Phone died on me so I couldn't take any pictures but then I sanded once again, primed sanded and painted sanded and clear coat.
Cut out one baffles and will use that as a template for the other one with a flush trim bit.
Then test fit and looking good if I may say.
10314623_304788256346911_550609846228175
That's all I got so far, still have a ton of work left to do.
Cool work man. It's nice to see when someone says they are going to wall a Civic, they wall the Civic. I'm tuned in :)
This is what I was bumping before I got the Civic to wall. Dodge Journey with 2 AQ HDC3 on a AQ2200 did a 147.9
Wanted more so I pick up a second AQ 2200 and built a new box and amp rack.
Then we found out we were excepting baby #4 and needed to put the 3rd row of seats back in. Never got a chance to install the new box and rack in the Journey cause it all came out. The wife told me to find a small car and do what I what to it, always wanted to try a build a wall so I started looking. Found the civic and it was on, had the civic 3 months and this is my 3rd build in it.
Loving it so far man! Like the previous set ups too.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Hell yea, great craftsmanship, lots of builds too bro, Tuned in!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Did some more work of the last few days.
Got the port primed, painted and cleared.
10411137_306113412881062_227012436184690
Port and 2 baffles installed.
1979617_307154752776928_9968371817754398
test fitting 3rd baffle, I couldn't hold it and take a picture so so its just sitting on the floor.
10441429_307136706112066_374913440969520
Making the 3rd baffle.
10443425_307156326110104_545656303140520
Sprayed some foam around the second baffle.
