4th order walled Civic (DC/PSI 18's/CF 8K/ RF 360.3 UPDATES APRIL 24-2015
I didn't think DC's liked fourth orders.. I could be wrong?
The DC's are out of JD truck of Team Asshole, they do very well in a 4th order.
I meant center port with subs firing into sealed section firing at the rear side windows, motors facing each other in the center
Oh ok ya don't have teh room to do two seal chamber, on second though I can't really say that as I never really check to see if that would work.
Why not just flatwall it with a driver side port? The extra space will help with efficiency and it doesnt seem worth the trouble if the bandpass doesn't come out how you want it.
Your really just restricting yourself if you think about it.
Had a flat wall wanna try a BP, it not hard to build and if it turns out I don't like it I can go back to a flat wall. This way I can say I tired a BP din't like it and gone back with a flat wall.
Makes sense
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
Got some more work in the last few weeks.
Did a little work on the 4th order wall, baffles and brace are done. Just need to glue, screw and paint the shell. Also started on the loading wall, this will be finish when I'm ready to test and tune the port.
Ready to start cutting, I cut the sheet down to a little bigger with a skill saw then wheat I need ten finish it with the table saw.
11053456_442121909280211_600192136882162
1382379_442121932613542_7041596257120390
11016093_442122002613535_445724680777763
11150157_442887042537031_639309274348962
10926371_442887089203693_495150568197338
11167950_442887119203690_868009966980059
10520549_442887142537021_323980045603243
Time for the loading wall, I'm not done it yet. Should be working on it over the weekend,
Thats all I got done on the wall, I did glue, screw and fill in the screw holes in the baffle but didn't take any pictures.
Did a 96-98 Civic front end to a 98 Acura EL front end swap, engine bay wire tuck, blacked out the inside headlight and started on the body works.
10930070_440826999409702_478478141023463
10665326_440827039409698_142978929272470
Painted the front flat black, you were able to see the red under the bumper.
603767_440826979409704_44285498027171411
Then was installing the front end and making sure everything was align right.
11133939_440826816076387_905216618304762
Time for some body work, wife help me out with it but we did not finish ran out of sand paper. lol
My next two projects, did a 99-00 Civic heater/radio bezel so I can have a double din deck. Also will be going to be relocate the heater control to center console.
10923336_444234262402309_645004816930474
11150532_444234295735639_200888709342820
11127607_444234332402302_222214697667044
11150507_444234359068966_168764449074927
10385398_444234389068963_570150872077865
Time for some primer and sanding.
11188342_444556389036763_696154813212526
There some more sanding to be done.
482812_444556555703413_84427595458675690
10702231_444556405703428_177665057947002
Sanded some more and few more coats of filler primer, I like it.
It got cold here again, so paint and clear will have to wait till its nicer out side.
