justin_garrett Posted June 10, 2014 Report Posted June 10, 2014 Ok the way you have your subs wired is like mine if the coil's are in a series and sub's are parallel Wire going from one coil's pos to the other coil's neg on the same sub then the pos from one coil and the neg from the other going out to your terminal cup or bolts where both sub's hook up inside the box then one set of wires hook in to your amp from the outside of the terminal cup or bolts With a setup like that both subs should be receiving the same amount of power if you have a dmm i would check and see what each coils ohm's are Here is a pic so i don't confuse anybody http://www.the12volt.com/12voltimages/2_1ohm_dvc_1ohm.gif 1998 neon R.I.P 137.5 db's Youtube videos http://www.youtube.c...tingarrett64067 2000 Eclipse Headunit = pioneer avh-p1400dvd Subwoofers = 2 DC audio lvl 2 12's Amp= Vibe bass 5 1500rms @ 2ohms Single run of 0awg power and ground wire ( Big 3 wire upgrade comeing soon )
