i just brought set of skar audio fsx 6.5 and a set of crescendo audio ft1 with the crossover. is my rockford fosgate t400.4 going to enough power or should i look at buy another amp?
Head unit Pioneer deh-80prs
Sub Amp
Highs Amp Skar audio Lp 60.4
Tweeters and Highs 2 Skar audio fsx 6.5 and 2 spx-t
Subs
Batteries?
alt?
Depends, what are you wiring to and what are the rms ratings of the speakers?
I ran a pair of Rockford punch pro 6.5 and punch pro tweet in each door on a t400-4 and it powered them perfectly. Now if the tweets are rated for 75watts rms but you can only wire them to 8 ohms and only giving them 30-50watts but the mids can be wired to 2ohms and they are getting 100watts a each they might be overpowering the tweets. Adjust the deck could help balancing it out though. Only installing it will tell you if it is giving you what you want.
since you have it all already what I would do is hook it up and rum it for a few weeks. Make the tweaks and adjustments to get it to what you want or as close as possible to what you want. If after a few weeks/months you can't get it adjusted to your liking figure out where its falling short and ho from there. If the speakers can handle more power and you feel like more power will help buy a bigger amp. If you feel like you need a better midbass response try and find a midbass speaker that cab potentially give you the better sound or more output you want.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
