martydmb Posted June 14, 2014 Report Posted June 14, 2014 Sundown recommends a 350amp fuse for the saz-3500d v2. Im running it on a 300amp fuse right now but would like to get a 350amp fuse for it but cant find any but a bluesea which is $18.50 on amazon. I saw xs had a 350 on there main site but cant find who sells them at all. 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
TRON Posted June 14, 2014 Report Posted June 14, 2014 CE Auto Electric Supply: 350a ceramic for $9.95 http://www.ceautoelectricsupply.com/fuses.html Tony will hook you up right. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
martydmb Posted June 14, 2014 Author Report Posted June 14, 2014 Thanks. Ordered 2 just now. shipping was the same price for a fuse but whatever now atleast ill have the right size fuse instead of a 300amp anl fuse im using now. 05 dodge magnum rt DEH-80PRS Rockford fosgate T600.4 st200 tweeters Sundown Neo Pro 6.5 v2's 2 Saz-3500v2- Toolmaker dual 1/0 inputs 2 Sundown ZV4 12" D1 1/0 Sky High Power wire OFC 3 XS D3100- Toolmaker battery terminals Mechman 320 Amp Alt Smd Voltmeter KnuKoncept 1/0 OFC
audiofanaticz Posted June 15, 2014 Report Posted June 15, 2014 Fuse don't matter. If your 300 amp is not blowing, a 350 amp fuse will not do anything more than a 300 amp fuse except make it not as safe. Which means it will take even more current to blow that fuse if something goes wrong. These fuses are a slow blow fuse, just because its rated at 300 amps doesnt mean it will blow if 301 amps of current get passed through the fuse. To ideally make that fuse blow your talking 360+ amps of current to be passed through that 300 amp fuse for about a minute, maybe longer since it will have to build up enough heat to melt the actual fuse.
