Blowing Fuses
Alright guys yesterday my new amp came in so I went to my car unplugged the negative and swapped it for my old one. when I went and plugged the negative back on and the fuse blew so this morning I went to the audio shop bought a new fuse and blew that one as well
equipment is knukonceptz 0/1
200a anl fuse from knu
C2 audio recon 1.6
Stock electrical
Are you blowing the amp or the in-line fuse?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Did you remove the fuse before heading hooking up the amp?
if not remove the fuse fully connect the amp making sure it has a good solid connection then replace fuse.
if you did how long after installing the fuse did it blow?
by chance sid you pull at the wire at all?
best thing to do would be to pull the whole wire out and check it for cuts/tears. Make sure none of the wiring is grounding out. Check the amp by hooking it up in a different car. Reconnect the old amp and see if the problem keeps happening.
gonna have to do some testing to figure this one out.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 859 Guests (See full list)
