Daniel Francis Sheppard Posted June 19, 2014 Report Posted June 19, 2014 So I started from scratch and did the whole setup process for setting gains with the DMM-1. My HU's undistorted volume is 36/40. Then I went on to set my gains for my 4 channel which I had no problem doing. Then last I did my mono amp for my subs. The issue is that when my volume is at 36 and gain at 0 as soon as i turn the gain past 0 it says distortion. I feel like because of this now my subs are being underpowered. What can I do to remedy this? Do I have to reduce all my gains to match a lower volume or is there an amp issue going on?? The subwoofers sound entirely different since I made this change and do hit anywhere as hard.
SLAYER1805 Posted June 19, 2014 Report Posted June 19, 2014 I assume you mean DD1 not DMM-1. What amp? Is the H/U EQ settings set to flat with no bass boost on the amp?
Daniel Francis Sheppard Posted June 19, 2014 Author Report Posted June 19, 2014 yes the DD1. Mono amp is Alpine MRP-M500. EQ all set to flat. Bass boost is set at 6db on amp only but has been on that setting since I bought the amp back in 2007. Should I try setting the gain with Boost set on 0. I was pretty sure it said in the instruction manual to keep Bass boost at normal listening setting.
SLAYER1805 Posted June 19, 2014 Report Posted June 19, 2014 Turn bass boost all the way down and try it again. Guarantee you won't have the problem anymore
Guest Posted June 19, 2014 Report Posted June 19, 2014 turn ALL bass boosts off. they are useless if the amp is already set to output 100% clean power with the gain knob.
Daniel Francis Sheppard Posted June 19, 2014 Author Report Posted June 19, 2014 what should i use for bass boost ... the amp or the HU boost??
SLAYER1805 Posted June 19, 2014 Report Posted June 19, 2014 No need for bass boost, if you need more power get a slightly bigger amp and use the -5 track to tune it. It probably sounded louder to you than before tuning because you were clipping them which is no bueno. This happened with my first setup, it was louder but after I DD1'd it the output wasn't as much but it sounded WAY better
Daniel Francis Sheppard Posted June 19, 2014 Author Report Posted June 19, 2014 Also when I set the gain for my subs I have to leave them plugged in to get a signal. With my 4 channel amp I can read the signal through the positive terminal and amp ground without the rcas plugged in no problem. But for the subs the only way the DD1 detects the signal is if the RCAs are plugged into the amp.
Daniel Francis Sheppard Posted June 19, 2014 Author Report Posted June 19, 2014 No need for bass boost, if you need more power get a slightly bigger amp and use the -5 track to tune it. It probably sounded louder to you than before tuning because you were clipping them which is no bueno. This happened with my first setup, it was louder but after I DD1'd it the output wasn't as much but it sounded WAY better I set the sub gain with track 1 because i heard it was better since it was at 0 db.
truthsayer Posted June 19, 2014 Report Posted June 19, 2014 No, No bass boost. Use -5 track to set. truthsayer
