sbg Posted July 1, 2014 Report Posted July 1, 2014 Thinking of getting a xtr orion 3700.1. And just want to know what people think of it. $600 4 ohms: 1500 watts x 1 chan. 12.6v 2 ohms: 2500 watts x 1 chan. 12.6v 1 ohms: 3700 watts x 1 chan. 12.6v 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Hugh G. Rection Posted July 1, 2014 Report Posted July 1, 2014 makes me miss the old orion hcca stuff from the '90s Owner of BigAss Ports
truthsayer Posted July 1, 2014 Report Posted July 1, 2014 Good looking board. Wouldn't surprise me a bit if it does rated. Edit: Pasmag http://www.pasmag.com/car-audio/reports/3243-orion-xtr37001d-amplifier%C2'> bench tested it, and it does over rated power. truthsayer
sbg Posted July 1, 2014 Author Report Posted July 1, 2014 It is a vary clean board imo. At a good price. It would be pushing 2 SQ hdc3 12s 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Hugh G. Rection Posted July 1, 2014 Report Posted July 1, 2014 It is a vary clean board imo. At a good price. yet you ask what everyone thinks of it. Owner of BigAss Ports
sbg Posted July 1, 2014 Author Report Posted July 1, 2014 It is a vary clean board imo. At a good price.yet you ask what everyone thinks of it. OK? So because I think the boards clean I can't ask what others think? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Hugh G. Rection Posted July 1, 2014 Report Posted July 1, 2014 It is a vary clean board imo. At a good price.yet you ask what everyone thinks of it. OK? So because I think the boards clean I can't ask what others think? you said it was a clean board at a reasonable price. if you know enough about boards to be able to look at one and determine that its a reasonable price, then that would lead people to believe that you can look at one and dictate if it puts out power or not. since after all, if it put out well below rated then i doubt you would say it was reasonable price. Owner of BigAss Ports
Joe Jonsen Posted August 7, 2015 Report Posted August 7, 2015 I have the new model XTR 4000.1D... I have it wired down to .5 ohm using 2 massive audio hippo 12s and its incredible...
bassfreak85 Posted April 28, 2016 Report Posted April 28, 2016 counting the transistors unless its high voltage rails i'm gonna say right around 3500..
hunter1206 Posted April 28, 2016 Report Posted April 28, 2016 its a great amp i have one it puts the power out
