XS Power
How you liking the Taramps? Thought about buying the HD5000 2ohm to support the 12.5-13v situation I'm facing. I realized that I'm not dropping too much voltage (maybe a full volt at full tilt, as long as my batteries are topped off), which is ok to me and everything else is good to go. The Taramps have me interested, but the only thing holding me back is that I heard they don't like vibration to much. How did you get around this issue? I think by adding one more battery and securing the amp, or protecting it from vibrations, and I would be good to go...
Edited by dharris2488
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
i love the amps. so much power at a high ohm its crazy!!!!!!!!!!!!!. no they dont like vibration. just dont mount the amp on the box. u can install them on rubber feet like a msd box if your anal
Thanks for the update. I really want to put 2500 on each one of the Ethos, but to do it at 2ohm the conventional way isn't worth the price tag to me. Rather recone the subs and wire them to 1... The Taramps seem like they are holding up, as long as the vibration issue is properly taken care of... Thanks again
CT Sounds 4000.1D
(4) 8" PRV 8MB450's
Pioneer AVH-X4600BT
no prob man i must warn u thought within the first 5 min playing the taramp i blew 3 coil out of 8. the power these amps put out is just amazing i didnt even get the meter them with all 8 coils becaus i wanted to hear it. but with 5 coils wired to a 4.6 ohm load on a 2 ohm version taramp i metered 150.2db on music legal. with b ox rise. on lanzar opti 4k i did 145 sealed . my new speakers will be here monday and ill be back at full power. im attending the show at sundown hq on the 16th if anyone reading this is comming.
