Well, you got the low tune right, but what size sub is it?
The port area looks low. Given a lower port area will increase the velocity, but I still don't feel conformable with it.
Edit: you probably want at least one extra baffle and you need to account for sub displacement.
Edited by Krakin
Krakin's Home Dipole Project
15" zv4
when I called them today they said keep it at 14" per foot even when I said 15-16 they said 14 was best. I can add an inch here or there to make up the air space difference to account for an extra baffle and displacement
Rolex you sicken me.
Just let me finish my pie
~ Juice
Well, I'm not going try and bring down sundown or anything, because I do respect them a lot. However, I don't believe in the port per cube.
I go the route of port velocity and determining how much air is being moved and keeping it going under a controllable velocity, which with modern subs equates to some very large port per cubes.
This is a quick calculator to get you in the right direction.
http://www.carstereo.com/help/Articles.cfm?id=31
This will lower air velocity, but you are still going to be moving a hell of a lot of air, especially if you tune low.
Also, if there is someone reading this that knows a lot more about moving air than I, then speak up. I'm a SQ guy that knows a little about aerodynamics.
  • Who's Online   0 Members, 0 Anonymous, 554 Guests (See full list)
