Hifonics question
MatthewBigBossWilliams
OP, you do know that the brutus elite is supposed to be hifonics' best line? and thats the exact series steve used in his video.
edit: one detail was left out about that amp dyno test. the burp/dynamic number was done on above rated voltage. iirc like 15.1v or something. "rated" is 14.4v.
And here I thought my 15 was hitting super hard :'(
who ever said you had to run big amps at 100%? you can turn it down if you dont need, or cant support, full power.
@ 3k watts I doubt I would have to upgrade the alt unless I am attempting comps all day right? I should get bigger batteries then? I have 2 KHC 2000s
Keep those batts and keep your eye on the volt meter the first play
If your voltage drops too low, you upgrade
Don't worry about the alternator so much until you know how much draw you have
I think there is a guy on here running DC 9k or 10k on stock alternator with a bunch of batts, not a good idea but I hope you get the point
How is he even remotely able to keep up that charge with that much power? I could see him doing that @ 4 k watts but not 10k
I ran a brz2400, no way it did rated power at all. I now have a orion xtr3700 and is louder way louder to the ear at 4 ohm then the and brz at 1 ohm. Was 740$ and rated at 3700wrms @1 ohm 12.6v.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
there are a lot of choices. Hopefully I will have a video up. I ran the hifonics at .8 ohms and she is getting dumb hot at full volume lol
  • Who's Online   0 Members, 0 Anonymous, 9332 Guests (See full list)
