JimmyBaldin Posted July 18, 2014 Report Posted July 18, 2014 hello guys , i have a question about wiring. i have 5 2150 + 1 d3400 and a singer alt 250amp. 3 runs of pos and negative. i have 2 bc3500 and im not sure if i should wire them at .5ohm ea or 1 ohm. i will have 4 15" but im not always listening to music loud. i love to give demos to people. would it be better to run them parallel,parallel to 1 amp for a .5ohm load (2 subs out of 4) and same with the other 2 subs. or should i wire them series/parallel for a 1ohm load? i know that parallel,parallel is better then series parallel but would it affect that bad? subs will be crossfire c7 15"s . will my electrical be able to support .5ohm on ea amp (crescendo bc3500) and does impedance rise affect alot when playing daily? i know that the amplifier will never see the .5ohm with rise .
Aj11 Posted July 18, 2014 Report Posted July 18, 2014 that's a long standing debate. half say "don't run below the minimum independence" while others say "hell yea go for it" your alt can't handle both those Amps @.5 but you do have a decent size battery bank. but the bank is only good for so long. if 90% of the time your not full tilt and just Jam out to your radio. only really crank it for demos then i say run at .5 if your like me and play full tilt almost everywhere you go then stay at 1ohm. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
JimmyBaldin Posted July 18, 2014 Author Report Posted July 18, 2014 ok thank you . and no i do not listen to it all the time at full tilt. i prefer giving demos to people . normally i play half of the max volume. i have to say that i have 8 pwx 6.5 and 4 ft1. amps are 1 audio system 300.2 to the mids and 1 aq 120x4 at 8ohm to highs.
MrSkippyJ Posted July 18, 2014 Report Posted July 18, 2014 do you already have the subs? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
JimmyBaldin Posted July 18, 2014 Author Report Posted July 18, 2014 No i do not have the subs right now because they are out of order. Thats why im asking the question now to know if i get dual 1ohm or dual 2's
JimmyBaldin Posted July 24, 2014 Author Report Posted July 24, 2014 does anyone ever experienced problems with overheat with crescendo bc3500 at .5ohm?
