Skyfall Posted July 21, 2014 Report Posted July 21, 2014 Needs to power 2 kenwood kfc w3013ps 12" @ 400 rms..
Noel989 Posted July 21, 2014 Report Posted July 21, 2014 What impedance are you your subs? Is the 400 watts each sub or both? Here's a suggestion $10 more than your http://www.soundqubed.com/Q1-750-Amplifier_p_46.html Build Log - http://www.stevemead...-cruiser-el-pt/
Skyfall Posted July 21, 2014 Author Report Posted July 21, 2014 4 Ohm@ 400 rms per sub also there SVC
Noel989 Posted July 21, 2014 Report Posted July 21, 2014 4 ohm single coil 400 watts Once you wire them you'll be at 2ohms If you get the soundqubed q1-1200d it'll do the power your looking for But it's $69 more Build Log - http://www.stevemead...-cruiser-el-pt/
LemonyGuy Posted July 21, 2014 Report Posted July 21, 2014 Rockford fosgate prime 1200d is around 800 at 2 ohms if I remember right.
broncosean Posted July 25, 2014 Report Posted July 25, 2014 The american bass phantom 2500 will do 1250rms @ 1 ohm so i would think that youd be around 800 @2 ohms and you can pick them up online a little over 200. same for the american bass vfl hybrid 2680.1D. I have never owned an AB but have heard good things. Could also look into the hifonics brutus elite 1200.1D http://www.woofersetc.com/p-12294-be12001d-hifonics-monoblock-1200w-rms-brutus-elite-series-class-d-amplifier.aspx but im sure some people are opposed to hifonics because theyre overated but from what ive seen theyre still fairly reliable, in my opinion your asking for too much on to little budget unless you buy used. Your best bet is probably to spend the extra $50-100 on an amp like soundqubeds, it'll benefit you in the long run 1994 Ford bronco Infininti kappa 4 channel driving a pair of reference 6.5s and a pair of 6x8 kappas downfiring console w/ a pair of image dynamic 8s on a memphis 250.1 1999 Honda Civic Si front doors- image dynamics ctx 6" coaxial with ID tweets Back deck- Image Dynamics ctx 6x9" coaxials Bass- PSI platform 1 12" in a 4th order tuned to 39hz Amps- CT sounds 60.4 highs and mids, Ampere Audio 1k bass Power- Big 3 upgrade, second juicebox 50ah battery, sky high 1/0, skyhigh battery terminals
zZZzzzSnooze Posted July 31, 2014 Report Posted July 31, 2014 Any Boss amp, JK.... Audiopipe APCL-15001D http://www.sonicelectronix.com/item_81646_Audiopipe-APCL-15001D.html 900 @ 2-ohm This video here caught my eye: this one here is instock now: http://www.sonicelectronix.com/item_81647_Audiopipe-APCL-18001D.html 1150W at 2-Ohm both come with a Wired Remote Bass Level Control & Fuse Holder, ANL fuse I think. Vid Two:
khinds94 Posted July 31, 2014 Report Posted July 31, 2014 Any Boss amp, JK.... Audiopipe APCL-15001D http://www.sonicelectronix.com/item_81646_Audiopipe-APCL-15001D.html This video here caught my eye: Videos like that make me hate the dyno 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
