problem with dd1
Okay guys I just used the multi meter on the amp 29 volume gain all the way down shows like 36 volts which is not correct it should be lower like 6 etc now the very interesting part is when I turn gain up voltage decreases so at max gain volume 29 it is showing less than 6 volts I can take pics bc I doubt anyone will believe me
Where are you taking the reading?
SMD Super Seller
My Feedback Thread
Taking reading from sub I'm not lying the voltage decreases at max gain it's like its reversed is that possible I can take a pic hold on
Okay it's set perfect the gains were backwards on the amp or something because I checked and rechecked with both the dmm and dd1 at clean signal 33 sub level 15, for everyone saying not to set sub level at 15 you were incorrect in regards to alpine headunits I figured this out because with sub level at 0 the max voltage the amp would see was 22 volts which 1200 watts should be 36 volts so I set sub level to 15 volume at 33 gain knob turned to what is labeled on amp as 6 volts the max and did not get distortion kept "turning down gains " until solid distortion light came on. Then hooked up dmm so I could see the volt reading instead of being 54 which is what it was with gain knob all the way down it was now at 37 so it was perfect. Double checked this and everything checked out. So thank you everyone for all the help I guess we can see why it took so long . I can't believe I figured this out I should PayPal everyone who helped a gift :)
