Pasta Prime Posted August 6, 2014 Report Share Posted August 6, 2014 What precautions do you take when welding on your rig with your audio already installed? Just unhook your grounds? New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66 Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 6, 2014 Report Share Posted August 6, 2014 I welded my broken door latch, undid the pos/neg of the battery/front rear runs. And all the grounds to all the amps. Everything was fine for me. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Pasta Prime Posted August 6, 2014 Author Report Share Posted August 6, 2014 Ok cool thx New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66 Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 6, 2014 Report Share Posted August 6, 2014 Ok cool thx yup.... also, put the grounding clamp as close to where your welding as you can. Again, all this worked for me. Good luck on yours bro. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
fox_racin4 Posted August 6, 2014 Report Share Posted August 6, 2014 I've done it with everything hooked up with no issues before, mainly because of how hard it is to unhook everything thing. A parts store should have a surge protector to rent out it just clamps onto your battery, I use one at work since semi ECUs are much more sensitive then car ECUs 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
Pasta Prime Posted August 7, 2014 Author Report Share Posted August 7, 2014 Mines easy enough to unhook so that is what I will do if i decide i need to weld. I got an idea to put my second battery but haven't mocked it up yet to see if it will even work out the way it looks in my head. lol New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66 Link to comment Share on other sites More sharing options...
1badgsd Posted August 20, 2014 Report Share Posted August 20, 2014 Ground clamp as close as possible to work and you'll be fine. Link to comment Share on other sites More sharing options...
