Babyboy4you93 Posted August 6, 2014 Author Report Posted August 6, 2014 Nope rcas are ran on the opposite side and I can try and post one and I have a pioneer deck but it has done it with every system I've had I've tried everything
Aj11 Posted August 7, 2014 Report Posted August 7, 2014 its your ground.. or maybe cheap rc cables. i would take the 2 hours ground your deck and amp to the frame of your car. not a seat bolt, shock tower, or anything else! the frame! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
philrab Posted August 7, 2014 Report Posted August 7, 2014 Also need to consult the Wire/Fuse chart and see if the max amps for 4 gauge wire (125 amps by memory) will cover the fuse ratings for both your amps. If not, your power wire is too small. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Aj11 Posted August 7, 2014 Report Posted August 7, 2014 you fuse the wire not the amp. and the 4g is cutting it really close for both. it won't hurt your car, just choke your gear. a wire can't be to big for a amp. but it Can be to small. but not.knowing the power that the 4channel makes and guessing that your hifonics amp makes around 800/900w your right on the limit for the 4g. i think someone here just clamped a hifonic 3200.1 and got Just over 900w jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
