How To Set The Gains For 2-way Speakers?
hello, i will be ordering 2 sets ofthese this week! they are 70rms each, so i would like to run them from a old amp i have, which is a 4x50rms @4OHM this
is what i need to know is
A: what voltage do i set the amp to to give out 50rms to each of the four speakers? do i set the amp simply to 50rms@4OHM, or 200rms@4OHM? or what do i need to do? use this
B: what test tone(Hz) would be best to play whilst i set the gains? and do i turn the volume to 3/4 full like i did when i set the gains for my woofer!?
thanks in advance for input, i really appreciate it :)
Beckett!
*Alpine Typr-R 12"
*JBL GTO 1200.1 Sub Amp
*Alpine PDX-4.100
*Rockford Fosgate Power 6.5's
*Rockford Fosgate Fanatics 6.5's Both in front doors
*0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator)
*140 Amp HO Alternator
*Alpine Head Unit
-------------------------------------------------------------------------x------------------------------------------------------------------------------
umm?
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
A: 14.1v each channel (50w @ 4ohms)
B: I tuned mine at 1khz so I wouldnt burn up the tweets
C: 3/4 is about right, if your running an Alpine it might be closer to 3/5
thanks man :) proper helpful!
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
hi, today i tried to set the gains, used a 1khz test tone, at volume 26/35. on the voltmeter it was only coming up with 4.odd volts with the gain set to max sensitivty and less than that when i was turning it down!
i have this amp, how do i set the amp to get 14.1 volts each channel??
amp pic 1
amp pic 2
those pisc might be useful :)
thanks Ben.
EDIT;
here is how i have the rca's in the amp it has on the amp either 'A' or 'A+B' for the rca's, not sure which one to put it in?
and here is how the speaker wires are wired into the amp (4 2-wayspeakers total. they are not wired up yet, i just prepared the wire at the amp end)
also i dont have any manuals for the amp due to i bought it second hand ages ago.
i seriously would like help asap because i have nearly fitted all the speaker brackets etc
thanks again
Ben Beckett!
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
EDIT:)
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
is there any special way i need to connect the speaker wires to get 4-OHm, ? my speakers are 4 ohm so do i just connect them like i have or what?
please help.
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
MORE RCAs!!!
if you can run another run from your deck (if it has two sets of RCA outputs) OR get a splitter to run an RCA set to front and back for full signal!!
-Drew
uhoh_45 said:
