kcarter1227 Posted August 7, 2014 Report Posted August 7, 2014 Hello all, getting ready to start ordering parts for a build, this question will pertain to the highs and mids aspect of it. My plans are to run an AQ 200.2 which is 340x2 at 2 ohms. For speakers I'm really interested in using the Incriminator I65C components, they will match the Lethal Injection's I'm wanting to run off of my AQ 2200. The I65C's are listed as 4 ohms I was going to buy 4 sets, they are listed as 85 watts per side so two full sets would go to each channel. My question is how will the impendance work? I know if I wire 4 mids and 4 tweets per channel I can get them at a 2 ohm impendance if each speaker is 4 ohms but when wiring to a crossover how does that affect impendance ? From what I understand, each set wired to a crossover will give me 4 ohms by themselves but if I wire 4 crossovers, the safest load I will be able to run is four ohms.... I don't mind running without crossovers, I know it will complicate things but I'm open. Any help is greatly appreciated ! Team Lethal Pressure Vice-President 2002 Ford F-150 Supercrew -Taramps DSP 3000 (subs) -Taramps DSP 1600 (mids) -8 Skar Audio FSX Mids -4 Skar Audio VX35-ST Super Tweets -85' of 1/0 EB Flex Welding Cable -XS D3400 under the hood -Datasafe 12HX505-FR in the rear (110 ah) -Pioneer AVH-2700BS -2 Soundqubed HDS315's -4th order Blowthrough -100 Sq. feet of deadener (Qmat, GP STFU, Noico) -147.8 @ 40 Hz -Top 5 in 904 SPL Outlaw's Walled List -Rebuild on the way
n8ball2013 Posted August 7, 2014 Report Posted August 7, 2014 run them passive itd your only option THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted August 7, 2014 Report Posted August 7, 2014 and two sets ran passive witha. 4ohm set is 2 ohm per channel.2 ohm stereo ok. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
kcarter1227 Posted August 7, 2014 Author Report Posted August 7, 2014 When it says two sets, that's only referring to 2 crossovers as in like 4 mids/tweeters? Because I'm buying 4 sets which will include 8 crossovers total connected to 8 tweets and 8 6.5's so it will be 4 crossovers per channel? Team Lethal Pressure Vice-President 2002 Ford F-150 Supercrew -Taramps DSP 3000 (subs) -Taramps DSP 1600 (mids) -8 Skar Audio FSX Mids -4 Skar Audio VX35-ST Super Tweets -85' of 1/0 EB Flex Welding Cable -XS D3400 under the hood -Datasafe 12HX505-FR in the rear (110 ah) -Pioneer AVH-2700BS -2 Soundqubed HDS315's -4th order Blowthrough -100 Sq. feet of deadener (Qmat, GP STFU, Noico) -147.8 @ 40 Hz -Top 5 in 904 SPL Outlaw's Walled List -Rebuild on the way
evermaxx Posted August 7, 2014 Report Posted August 7, 2014 youll need another 200.2 Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
kcarter1227 Posted August 7, 2014 Author Report Posted August 7, 2014 Unfortunately the amp puts out too much power for only 1 set per side, it'd blow em In a jiffy and 4x85 is 340 which is what the amp puts out at 2 ohms Team Lethal Pressure Vice-President 2002 Ford F-150 Supercrew -Taramps DSP 3000 (subs) -Taramps DSP 1600 (mids) -8 Skar Audio FSX Mids -4 Skar Audio VX35-ST Super Tweets -85' of 1/0 EB Flex Welding Cable -XS D3400 under the hood -Datasafe 12HX505-FR in the rear (110 ah) -Pioneer AVH-2700BS -2 Soundqubed HDS315's -4th order Blowthrough -100 Sq. feet of deadener (Qmat, GP STFU, Noico) -147.8 @ 40 Hz -Top 5 in 904 SPL Outlaw's Walled List -Rebuild on the way
evermaxx Posted August 7, 2014 Report Posted August 7, 2014 then get a 120.4 i believe sq has now. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
kcarter1227 Posted August 7, 2014 Author Report Posted August 7, 2014 Dang, I'm trying to match my amps, I have an AQ 2200 d and I know where a bunch of 200.2's are at but not an AQ 120.4 Team Lethal Pressure Vice-President 2002 Ford F-150 Supercrew -Taramps DSP 3000 (subs) -Taramps DSP 1600 (mids) -8 Skar Audio FSX Mids -4 Skar Audio VX35-ST Super Tweets -85' of 1/0 EB Flex Welding Cable -XS D3400 under the hood -Datasafe 12HX505-FR in the rear (110 ah) -Pioneer AVH-2700BS -2 Soundqubed HDS315's -4th order Blowthrough -100 Sq. feet of deadener (Qmat, GP STFU, Noico) -147.8 @ 40 Hz -Top 5 in 904 SPL Outlaw's Walled List -Rebuild on the way
evermaxx Posted August 7, 2014 Report Posted August 7, 2014 then get another 200.2 and just keep gain low. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
