Arnold55 Posted August 11, 2014 Author Report Posted August 11, 2014 so am I at 1ohm if the subs are wired like this http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=42#results in each chamber of the box? or is this the only way it should be http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 you cant wire two d4 woofers to 2 ohms. clear up the information please. two d4 woofers can ONLY be wired to 1, 4, and 16 ohms. two d2 woofers can ONLY be wired to .5, 2, and 8 ohms. all +'s together and all -'s together = 1 ohm for you. IF you have dual 4 ohm woofers. if you have dual 2 ohm woofers, thats .5 thats what I needed to know thanks kranny, still new to this so I'm learning as i go.
