Can somebody explain what an item like this is used for. I noticed some stereos come with this and i was wondering what is is actually for. I always thought that high level output was measured in watts and used to actually power speakers and rca or low level is measured in volts and is used to "communicate" a signal from HU to amps/processors. Being two different types of power i thought you couldn't just split the positive and negative and had to use a high to low level converter. Can anybody shed some light on this topic
-2004 Ford explorer
-Pioneer Deh-80prs HU
-4 Rockford Fosgate R1683
-2 Rockford Fosgate P1S4-12 wired to 2ohms
-1 Rockford Fosgate Prime R500-1
-I know it's very basic...
It's for radios that do not have rca outputs which mean mostly stock headuntis. The RCA's would go I to the amp and the speaker wire you wire into usually your rear speakers or whatever speakers in the car which are closest to the subs.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
They make those because some amps, rca inputs now except high level ( speaker ) inputs. So you need the adapter. Pioneer is one of the ones off the top of my head, and im sure their are others.
truthsayer
  • Who's Online   1 Member, 0 Anonymous, 1821 Guests (See full list)
