Hertz HX300 sealed Sub Enclosure ...help needed
kuda427
Hey all
New to the forum
Been lurking quite a while though!
Anyway
Im setting up a SQL system in my 08 Maxima
Ive decided to drop down to 1 12" sub in the trunk
The sub is a Hertz HX300
From what Im told they perform Nicely in a 1.3 cf sealed enclosure
So...This is what im planning on
The Amp is a Arc Audio 2150se bridged...so give or take 600 rms max
My components consist of a set of Hertz HST 165s and a pr of Hertz HCX 165s powered by a Arc 4100se
Im looking for a nice clean bass effect
Thanks in advance
Can anyone Please help me with a design or specs for this build??
Welcome, nice stuff hope it gets a head unit to match, on the box here's a 1.3 cubic feet net box as you have requested, figure is just an assembly guide, use poly-fill or other damping material as recommended by the manufacturer:
You can use the same box for the TDX, you could just swap subs to test, for your type of application I would stay sealed with either sub, if you want ported just to test I could give something but based on the sub data and their recommended box it looks it will play nicer on sealed, sure enough ported will be much louder and efficient.
I may try that
But Im still interested in maybe doing a ported for days when I want it loud....lol
Seriously. ...wouldn't mind something ported that will produce good SQL results???
(Besides, I've got a 3/4 sheet of 3/4 mdf sitting here...with another box written all over it..lol)
I have a pwk design for a box..but its a very serious box!
About 6 ft or port!
@ 1.99 cf net
I believe it was designed for a DD 2000w sub
Too much ya think???
Im gonna try the 1.3 this weekend.
Gotta get the 80prs installed also
Do you by chance have something ported that may work for either sub that will still produce good sq??
I've read that if designed correctly and ported can and will provide good SQ
Any truth to this?
  • Who's Online   0 Members, 0 Anonymous, 4010 Guests (See full list)
