new buid 2 sd 8 d4 with ct 1400.1 amp. any ideas?
brandonp17
Sounds good but want the bass to sound deeper
You need a box with the port tuned lower
What are the settings on your amplifier tuned to?
iam not sure what the amps tuned at right I've only havd the ct amp for a day was running a auto Tec mean machine 500watt but it could push both subs pop fuses after running it for 10 min or so
if you were popping fuses and do not know how you have your new amp setup, something is wrong.
Can you post a picture of how you have your settings on the amp? that could be why your bass is not what you want it to be.
Also a picture of your amp ground, thanks.
It will be a little bit befor I can send any pics of the box set up and ground wire, and the ct amp is barely even turned up. How I set the gain was turned the raido up to were I wanted it then adjusted it with the bass, lpf,subsonic,and phase tuned all the way down the bass is 1/4 turn lpf is a little over 1/4 turn and the subsonic the same
and subs are wired in parallel at 1ohm
How did you figure your volume of your box? Did I read it correctly where you think you have 5.5 cubic feet of volume? If your box is 50" wide by 10" tall, by 10" deep(i have NO clue what you're referring to with whee the 3" on that back side comment", you're actually at 2.02 cubic feet before sub displacement and port displacement. I don't know what you're using for your math or maybe you posted your outer dimensions incorrectly.
My suggestion is to give us max useable dimensions and let us design you a box that is correct. The box you have, my feeling anyway, needs to go in the scrap pile. There nothing wrong with that, we've all made mistakes.
2009 GMC sierra extended cab,2sd 8 d4 shallow mount ported box for under the back seat front fire, from door to door 55 inchs wide 10 inch on the bottom and 13inch on the top
If you're using 3/4" wood, and assuming you're at 10" depth(measured externally) I come up with 2.63 cubic feet, before sub and port displacement. Pictures well help a bunch.
  • Who's Online   0 Members, 0 Anonymous, 1393 Guests (See full list)
