3sixty.3 setup question
Ok I am getting ready to start a build on a 2013 Dodge Dart. I am keeping the factory head unit, I want to keep factory navigation and steering wheel controls plus all my climate is controlled from my touch screen. I am going to tap into the speaker wires from the factory radio to the 3sixty3. My question is if I just use the front left and right to the 3sixty.3 will I be able to send a signal out to my amps to mid bass, tweeter and sub with just those inputs? It would be like this:
On the 4 channel amp from the 3sixty.3 I would like to use 2 channels for my mids and 2 channels for my tweets and then from the 3sixty.3 to my mono amp for my sub. Would this work? I am leaving the rear speakers on just the factory power.
Thanks
  • 2013 Dodge Dart
  • Factory HU
  • Rockford Fosgate 3sixty.3
  • Alpine V9
  • Alpine F4
  • Hertz HT-25 Tweeter
  • Hertz HL-70 Mid-Range
  • Hertz HV-165L Woofer
  • Raspberry Pi - Running OSMC using optical out to 3Sixty.3
  • Wiring - Sky High Car Audio
Build Log - http://www.stevemeadedesigns.com/board/topic/190450-2013-dodge-dart-american-bass-install/
You won't be able to hear the rear... cause the fronts should definitely overpower. Plus idk of any or many tweets that can handle a full channel's power. But yeah. You would leave the rear speakers connected how they're connected and connect the rest to the 360. So you should know which wire is what. Forget what exactly the 360 will do, but it'll be fine.
In short, leave the rear speakers connected and connect the rest to the 360. So the 360 should NOT have the rear speakers wires.
edit- And also, you'll be able to use the EQ and all to send the tweet signal to the tweets and mid signal to the mids... so that's not an issue. But, I'd recommend hooking them all up to the 360. Not sure what amp or tweets but that sounds like a baaaad time for those tweets to have their own separate channel....
Sheena = pedobear
Thanks for the reply. I will be sending them 45 watts. They are rated at 100 RMS
Here is the link to the tweet.
http://www.americanbassusa.com/product.detail/product_id/197
  • 2013 Dodge Dart
  • Factory HU
  • Alpine V9
  • Alpine F4
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
