B-Large Posted August 17, 2014 Report Posted August 17, 2014 I'm going to be installing a component setup and the only wire I have enough length of to use is 16awg Knukonceptz. The components are Hertz hsk165xl, and amp is an alpine pdx150.4. I plan on using the 16awg from the crossover to the speakers. Should I be using something larger from the trunk mounted amp up to the crossovers?
evermaxx Posted August 17, 2014 Report Posted August 17, 2014 It'll be fine Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
B-Large Posted August 17, 2014 Author Report Posted August 17, 2014 That's what i figured just didn't want to cheap out if larger wiring would be better.
alaskanzx5 Posted August 17, 2014 Report Posted August 17, 2014 I ran a t400.4 from the back of my hatchback to the front doors using 16g. No issues what so ever. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
