Need help with a box design for dual SA8-V2
id be gratful for some assistance with a simple box design (With specs) for dual SA8-V2 which i will be Hifonics BRX 1100.d. thank you
If you want simple, what's wrong with Sundown's rec? http://www.sundownaudio.com/misc/Boxes/SA-SD-E%20boxes/Sundown%202-8s.skp
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
What "more" are you looking for? That google sketchup pretty much lays out the most appropriate box for the subs you have. If you have some sort of space limitations, running more or less than rated power, ect. and need a design to reflect that, you gotta let us know what exactly you're doing.
Can't help you without all the info.
Build Thread
okay well i have a 2006 Mazda 3 (sedan), and i'll be wiring down the subs down to 1100 rms @ 1 ohms, just looking for a good ported box, if i am to use the one below where would the cutouts be ? at the top or front ?
My suspicion is the cutouts would be up top. Have you measured your trunk to verify if that'll fit, and to make sure you can actually get the completed box through your trunk opening?
Are you planning to build this yourself, or if you lack the skills you may want to ask around to see if someone local to you can do the construction for a price.
Build Thread
