Guest Posted September 24, 2014 Report Posted September 24, 2014 1000w at 3 ohms at 12v for a 2000w amp? its overrated
poorfish88 Posted September 24, 2014 Report Posted September 24, 2014 SoundQubed 2200 is worth every cent. Solid amp can run low voltage low impedance and still keep going. Every SQ/AQ amp I have clamped did rated or higher, and I have clamped a bunch of them.I've yet so see someone prove accuracy of a clamp test :/.And i can't say my testing method was 100% accurate either, but in comparison to the other amps tested in the same way, i was underwhelmed. Afficianado I see them do rated or above all the time? Maybe it was a lemon? entirely possible. My friend and i were very surprised, we expected it to do well over rated.I went in to the testing HOPING for it to do well over rated, i certainly didn't want it to fail. but the results are the results. I don't claim my dick is 12 inches long, but if the tape measure I am looking at says so am I lieing ? God Damm am I is working with a monster.
Afficionado Posted September 24, 2014 Report Posted September 24, 2014 My only experience with a SQ amp was that I got one for a friend and it didn't do rated power :/. When an amp doesn't even do rated, I'm not terribly impressed. Others experiences will vary. could still be a great amp for your application. here we go again. Here we go again Now you tellin me That she is just a friend Then why she callin you At 3 o'clock in tha mornin oh oh SoundQubed 2200 is worth every cent. Solid amp can run low voltage low impedance and still keep going. Every SQ/AQ amp I have clamped did rated or higher, and I have clamped a bunch of them. I've yet so see someone prove accuracy of a clamp test :/. And i can't say my testing method was 100% accurate either, but in comparison to the other amps tested in the same way, i was underwhelmed. Afficianado I see them do rated or above all the time? Maybe it was a lemon? entirely possible. My friend and i were very surprised, we expected it to do well over rated. I went in to the testing HOPING for it to do well over rated, i certainly didn't want it to fail. but the results are the results. I don't claim my dick is 12 inches long, but if the tape measure I am looking at says so am I lieing ? The comparison would be measuring your dick with a food scale. 12 g =/= 12" If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
