2009 Volvo V50 (It's got no name)
Not had a system in the car for about a year now, and that's gonna change next month.
Head unit: OEM and I will be adding on a Grom Audio interface (I don't have the USB interface in my car and the OEM unit does not play MP3)
Amps: SoundQubed Q4-120 and Q1-2200D
Subs: Either DC L3 12 or RE Audio SEXv2
Front Stage: Prob stuff form Dayton Audio, 2 way active setup
I'll be adding at least 1 XS Power D3100 in the near future and will do my alt upgrade next year when I get my timing belt replaced. That will be 270amp.
This is going to be a long drawn out install.
Box will start next weekend., Maybe.
But for now, here is a little porn.
Fedex man dropped off a goodie for me.
Level 4 18 D2. I still need to put lugs on 4g and 1/0 for my amps. But box is finished and ready for sub. I'm going to try to at least get the sub and the sub amp wired up Sunday.
Front stage is looking like Dayton Audio Reference 7" (friend ordered the 8's and no way I'd be able to get them in the doors) and Morel MDT-12 tweeters. Front stage will not be installed till I get my 3sixty.3, which might be a month.
I've toyed with the idea of going with a 3 way front stage, but that means adding another amp since I want to run all active.
  • 9 months later...
Ok, finally started over today. Box is cut, just needs to get 45's put in, port cut out/rounded, speaker opening cut, and glued/nailed. We built ther box on ther bigger side (2.52ft3 @ 29hz). We will loose some space due to th 45's and some bracing,. Should be in the car Friday for testing. Need to see if the SQ 750w amp does it or of I need to get the SQ1200w.
Gear list as it sits.
OEM HU
SoundQubed Q4-120
SoundQubed Q1-750
AudioControl EQL
Sundown SA-12
Rockford Fosgate PUNCH PPS4-6 6.5"
Morel MDT 12 1-1/8" Neodymium Tweeter (love those tweetersd, been using that model since around 2002)
