deadbroke Posted August 22, 2014 Report Posted August 22, 2014 If a 2 way component set wired to a passive crossover is 2ohm what does that make the impedence of each speaker? Components in question are the re xxx 2 ways
OrionStang Posted August 22, 2014 Report Posted August 22, 2014 Its actually irrelevant. Its important to know what the amp is seeing, in this case 2 ohms. Sorry, I can't answer your actual question. SMD Super Seller My Feedback Thread
deadbroke Posted August 23, 2014 Author Report Posted August 23, 2014 well I planned to run them active so I was figuring what type amp to match them with and what wattage I can expect to see since I won't be using the crossovers. I guess I could have said that
csshakka Posted August 23, 2014 Report Posted August 23, 2014 I would try to explain it, but it wouldn't go well. This thread has a couple posts that explain it decently. http://www.avsforum.com/forum/155-diy-speakers-subs/1220221-2-way-w-crossover-total-impedance.html EDIT: You could also just get a multimeter and measure resistance of the drivers too
